need help? converting obd0-obd1
yes u do. you will also need obd0-obd1 adapter harness,obd1 ecu. you will have to replace ur injector plugs,distributor plugs(on the harness not the dist. it self),reverse light plug,fan switch connector and oxygen sensor plug with obd1 plugs. and ur resistor box needs to be removed
NITROUSTOMMY
Jul 4, 2009 10:20 PM
19crxsi90
Jul 24, 2008 01:17 PM
projectef
Jun 24, 2006 09:36 PM
