OBD0 to OBD1 (1990 B18A1 into 1992 EG)
What can I do to convert this motor to OBD1??? Will changing the intake manifold and dizzy from an OBD1 Teg work???
Re: OBD0 to OBD1 (bbissell05)
if you want to put an OBD 0 integra engine into your EG, you will need an OBD 1 dizzy and alternator.
Some of the connectors might change, but you can always pull them and swap them from the obd 1 engine.
good luck
good luck
