shift linkage?
Old Jun 8, 2006 | 09:00 AM
Flava's Avatar
Default shift linkage?
do i use the oem shift linkage if i get a h22 swap into a 96-00 civic hatch?
also can i use any shift linkage if i get a gsr swap into a 96-00 hatch? or does it have to be from a 99-00 si?
Old Jun 9, 2006 | 03:32 PM
dynamo's Avatar
Default Re: shift linkage? (dingy)
Don't know about the H22, but you will need the 99-00 Si linkage to use with a GSR motor in a 96-00 hatch. Integra linkage will rub on the secondary o2 sensor, make a shitload of nasty noises and eventually break the sensor.
Old Jun 10, 2006 | 07:12 PM
djbutler007's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dingy &raquo;</TD></TR><TR><TD CLASS="quote">do i use the oem shift linkage if i get a h22 swap into a 96-00 civic hatch?
also can i use any shift linkage if i get a gsr swap into a 96-00 hatch? or does it have to be from a 99-00 si?</TD></TR></TABLE>
if you arent going with an H2B kit you need the prelude or accord shifter cables
jtaylor16
Nov 29, 2009 09:24 AM
Flava
Jun 8, 2006 11:24 AM
10seconds
May 12, 2006 03:36 PM
siblue_gzer
May 1, 2006 08:38 AM
