Motor Mount Insert Install
Old Jun 28, 2006 | 07:46 AM
AlienKrOZ's Avatar
Default Motor Mount Insert Install
Two of my three motor mount bushings have torn now and I would like to replace them with the Enegry Suspension motor mount insert. How would I install them? Do i just place the insert over the broken bushing? Do I have to take out all the stock torn bushing then put the new inserts in?
Old Jun 28, 2006 | 10:59 AM
BoostedDC4's Avatar
Default Re: Motor Mount Insert Install (AlienKrOZ)
would like to know also.
Old Jun 28, 2006 | 11:44 AM
b16_DIM's Avatar
Default Re: Motor Mount Insert Install (BoostedDC4)
My inserts (ek) required seperating the two pieces of the mount and placing the inserts on either side of the bushing. If your bushing is just cracked you'll be okay adding the inserts; however, if the bushing is torn through, depending on the mount, you will probably want to buy new mounts.
Old Jun 28, 2006 | 12:32 PM
AlienKrOZ's Avatar
Default Re: Motor Mount Insert Install (d16_DIM)
it's completely torn
Old Jun 28, 2006 | 04:49 PM
b16_DIM's Avatar
don't rely on the insert then, get a new mount.
Old Jun 29, 2006 | 12:30 PM
hella_usdm's Avatar
check out this thred about filling the mounts, broken or now, with urathane specifically designed for engine mounts.
https://honda-tech.com/zerothread?id=1168043
Old Jun 29, 2006 | 01:48 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (hella_usdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16_DIM &raquo;</TD></TR><TR><TD CLASS="quote">don't rely on the insert then, get a new mount.</TD></TR></TABLE>
Agreed. The inserts just fill in the spaces between the rubber on the stock mounts. If your stock mount is broken, it will just push the inserts out of the way as it moves around. Replace the mount...
TypeRod
Dec 7, 2011 02:45 PM
Speed Infliction
Feb 2, 2007 03:29 PM
CRXified
Dec 28, 2006 08:40 PM
SOHC_Brian
Aug 11, 2004 11:30 AM
inzaneN1
Feb 26, 2004 12:23 AM
