Can you use a OBD2B distributor with OBD2A wiring??????
New User
I have a 98 Civic Dx that I am doing a swap on. I am using the factory harness and installing a 01 B20Z motor. The distributor plug is different. Can I change the plug to use the new distibutor with it or do I need a ODB2A distributor?
Thanks,
Thanks,
Re: Can you use a OBD2B distributor with OBD2A wiring?????? (DTAYLOR)
https://honda-tech.com/zerothread?id=1680812
wires 10 and 4 on OBD2a engine harness plug connect to the yellow/green stripe wire on your dizzy... as for everything else color to color.... look on the post above to find out where wires 10 and 4 are
