What is this plug for?
Old Jun 24, 2006 | 02:31 PM
SMOOTHN's Avatar
Default What is this plug for?
I had this plug on my old block... I blew that motor and found this plug left over... I pulled the connector off the block but the spot on my new block doesnt have this slot for the connector... what do I do? can i leave it disconnected? I think it was for the old turbo it had before i bought it...
Old Jun 24, 2006 | 02:39 PM
R.S.AKIMOTO's Avatar
* B A N N E D *
Default Re: What is this plug for? (SMOOTHN)
I'm not 100% sure but I think thats the fan switch on a OLD SCHOOL 88-91 JDM B16a motor.
maybe?
Old Jun 24, 2006 | 07:05 PM
Slopoke's Avatar
Default Re: What is this plug for? (R.S.AKIMOTO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R.S.AKIMOTO &raquo;</TD></TR><TR><TD CLASS="quote">I'm not 100% sure but I think thats the fan switch on a OLD SCHOOL 88-91 JDM B16a motor.
maybe?</TD></TR></TABLE>
Yep. The older b18a1s had them on the back of the block too.
The newer ones have the fan switch on the thermostat housing.
Old Jun 27, 2006 | 06:57 PM
SMOOTHN's Avatar
Default Re: What is this plug for? (Slopoke)
so i dont need this plugged in? there is no spot for it on my new block...
Old Jun 27, 2006 | 09:07 PM
Slopoke's Avatar
You should have a round two pin plug on your thermostat housing.
If you do, then you dont need to worry about the one on the back of the block.
Old Jun 28, 2006 | 03:03 PM
SMOOTHN's Avatar
thanks slopoke... now i have other plugs I need help with...
This plug is under my Dizzy, Do i need this? i founf one spot where there is no plug but i donthink it will fit... correct me if i am wrong
Here is the empty connector, And can i just cap off that other vacuum connection?
Thanks
Old Jun 28, 2006 | 11:14 PM
MrMike's Avatar
the first picture is either the vtec plug or a single wire O2 sensor plug from a CX.
the second picture is evap valve.
Old Jun 29, 2006 | 08:32 AM
SMOOTHN's Avatar
i cant find a place for the first plug but i have a cx with a b18a in it now do it need this?
also the EVAP i have one that goes to the canister already how about the top one? that is missing a hose?
Old Jun 29, 2006 | 07:38 PM
MrMike's Avatar
Default Re: (SMOOTHN)
if u have a CX then u need to convert to 4 wire O2 sensor. search for the wiring instructions. for the evap, one goes to the canister and the other one goes to an open vacuum hole in the manifold.
C_Rock77
Aug 18, 2011 08:05 PM
LoW ToNE
13
Jun 6, 2010 11:59 AM
Sirfallsalot243
Dec 22, 2006 08:37 PM
marc-111
Feb 21, 2006 01:12 AM
thatbluecrx
Feb 25, 2005 06:07 AM
