H2B EK, power steering?? Also wiring Q
Is it possible to run power steering with the H2B kit in a 99 Si? How/ who sells a kit?
What is involved in the harness mods?? I have a complete 99 si harness still in car, and a complete h22a8 harness with the engine and ecu. They are both OBD2 right? is it at all possible to use the complete Si harness ( does it just 'plug in'? ) and the h22 ecu? Or do i swap the entire h22 harness over? Or do i cut and modify the 2?
Struggling to find obd2 wiring help.
Cheers
Cheers
Re: H2B EK, power steering?? Also wiring Q (JordanCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JordanCivic »</TD></TR><TR><TD CLASS="quote">Is it possible to run power steering with the H2B kit in a 99 Si? How/ who sells a kit?
Cheers </TD></TR></TABLE>
Anything's possible if you try hard enough... most remove the power steering pulley of their crank pulley as there is a huge clearance issue.... Not sure where your p/s resevoir and all is either, if that will be a problem or whatnot
PM bserious to find out more - he is Seth from Quarter sports drag, the maker of the h2b kit.
not sure about your wiring problem, i used an obd1 harness with an obd1 motor and most things plugged/wired right in- it also depends what ecu you are using, with the p13 or whatever the prelude obd2 ecu is you have to wire up knock sensor and egr crap and something else i forgot... but with a chipped ecu you don't have to.
keogsr1
05-16-2007 11:29 AM
