2000 ex wiring harness on 96 jdm b18c IAB wiring!!
Which slot do i use on the ecu?? i am using my 2000 ex wiring harness and then at the ecu i am using a converision harness to switch from obd2b to obd2a. i found some info about the iab slot on the obd2a but not on the obd2b.
obd2a as follows:
Red/Blue ----> ECU @ A26
Black ---------> Ground (I used the starter ground)
but what about obd2b ? and since i am going to be using a harness to convert from obd2b to obd2a..do i still wire it to a26 ??
Modified by MRturbo at 1:11 PM 6/22/2006
obd2a as follows:
