Can not get my 99 ex with b20 to start. Reaching out for help.
Hello all,
I am new to the forum and so if i am messing up by posting my questions in this thread i do apoligize.
However right now the issue is i have recently swapped my 99 civic ex d16y8 with a b20b but it will only turn over not start. To be honest as far as which version b20 i am not so sure. However it does have a p75 head and a knock sensor if that helps. Right now my build is a b20b engine, a p75 head, a p75-a04 ecu, and a 99 civic ex wiring harness repinned to fit ecu. Here is the diagram I used to repin the ecu connectors. http://technet.ff-squad.com/wiring.obd2a.htm
Again the starter will turn the engine over all day, but that is it. I have checked for spark on each plug and i have spark on all four cylinders. I know that i have fuel going to the rail but not sure how to check injectors. Mechanical timing has been checked and double checked, but not sure if there is a way to adjusted distributer. Compression is even across all cylinders but still only at about 130. I can not get it to do anything other than turnover even with starter fluid. Not even the slightest cough.
So at this point i am lost and would appreciate any assitance.
Brian
Brian
Re: Can not get my 99 ex with b20 to start. Reaching out for help.
If you are referring to the ecu connector wires I am fairly certain that I do. Atleast I have them in the order according to the diagram on link link I posted. I marked each with it the original position and the position it was to be moved to before removing each one just so that if I needed to switch back or double check I could. And since then I have went through all of them again to recheck. So fairly certain they are in the right place according to the information I went by. However if that info is 100 percent accurate I can not say for sure you know.
Did you figure it out? Did you happen to pull the plugs to see what they look like? Any fuel on them?
Daniel99
07-08-2018 08:31 PM
Ginge72
03-12-2018 07:34 AM
motoem
05-07-2012 02:42 PM
