Poorman's Type R Question
Old Apr 19, 2012 | 07:19 PM
Wilka's Avatar
Default Poorman's Type R Question
What head gasket do I need for the b16 on gsr block? Do I need a timing belt from a b16 or can I use my gsr one, and water pump? What all do I need? Also can I use an ls intake manifold and what intake manifold gasket do I use if I do use that?
Old Apr 19, 2012 | 07:45 PM
Wilka's Avatar
Default Re: Poorman's Type R Question
bump.
Old Apr 19, 2012 | 08:21 PM
Deetz's Avatar
Crazy Honda Guy
A lot of your questions would be easily answered with a touch of reading, these have all been covered many times........i will help today though
Headgasket- same gasket for either PR3 or P72 head
Timing belt- need the longer belt found on gsr/type R. The block is taller than a b16, needs a longer belt, makes sense huh?
intake manifold- use any manifold that fits a b16/type r head, there are many choices. You can't use an ls manifold on a vtec head
Old Apr 19, 2012 | 08:22 PM
beecee18's Avatar
If this is not some kind of joke we would need some more info, OBD1 or OBD2 car
Old Apr 19, 2012 | 10:29 PM
Wilka's Avatar
Its an obd1 94 civic ex with a gsr swap
Old Apr 19, 2012 | 10:30 PM
Wilka's Avatar
And I guess that means I need to hunt down an intake manifold since the ls won't work, and the gsr's has the unique bolt pattern.
Old Apr 19, 2012 | 10:44 PM
Wilka's Avatar
Its 94 GSR block with an b16a4 head and I have the complete GSR so I guess I can just swap cams and torque it down? What torque specs do I follow?
Old Apr 19, 2012 | 11:38 PM
Wilka's Avatar
Unless you guys think its better to rebuild my gsr head? Keep in mind I'm going all motor.
Old Apr 20, 2012 | 05:41 AM
Deetz's Avatar
Crazy Honda Guy
either head makes the same power.....yes, it's been covered MANY times, search!!!
Old Apr 20, 2012 | 10:46 AM
beecee18's Avatar
If you want it to perform anywhere near a type R or call it a poor mans type R, you would need a---------type R intake manifold, or a skunk2 manifold which is similar but has more meat for match porting to larger than R TB's
Fat Chick Magnet
Oct 4, 2006 10:37 PM
Blazin Civic
Jun 15, 2005 03:38 AM
daturboslow
Mar 16, 2005 07:15 PM
murtnabila
Sep 13, 2004 12:18 PM
b16powwer
Oct 21, 2002 06:52 AM
