B20 quick questions!!
Old Mar 7, 2012 | 12:59 AM
MEn'MYEK's Avatar
Icon2 B20 quick questions!!
Okay so I got a hold of a B20b4 swap for my ek. Only problem is the block and head are completely dissassembled. While the pistons are out the block will be honed and decked with fresh piston rings added.
Now for the bearings, I read that I can use a b18 bearing set (main and rod) is that correct?
What gaskets will i need to rebuild the bottom end? And cant I use b18 gaskets to rebuild the bottom end as well?
I plan on reusing the b20 head I know i have to replace the valve stems and seals as well as the head gasket. But what else will i have to replace??
Anything else I should replace while the motor is out??
Thanks honda tech its really appreciated!!!!
Old Mar 7, 2012 | 01:43 AM
jbpnoman's Avatar
Default Re: B20 quick questions!!
Why would you use B18 bearings and gaskets, when you can just get B20 bearings and gaskets?
For the bottom end, you should replace the bearings, piston rings, oil pan gasket, and front and rear main seals.
To rebuild the head and put it all together, you should get a head gasket, valve cover gasket, cam seals, spark plug gaskets, intake gasket, exhaust gasket, and throttle body gasket. Valve stem seals can be checked for runout and reused, as long as they're within spec.
I'm sure I'm missing something somewhere, but most gasket companies make "bottom end" and "top end" kits that will come with everything you'll need.
Old Mar 7, 2012 | 06:32 AM
kyden's Avatar
you can use everything b18a/b on the bottom end minus pistons/rings/headgasket.
Old Mar 11, 2012 | 08:49 PM
MEn'MYEK's Avatar
Okay now I have a mount question!!!
I know I need:
99-00 Si Rear mount bracket (T-bracket)
96-00 CRV/ Del Sol Vtec Driverside front lower engine mount
What other mounts do I need?
Can I just get a simple D to B mounts kit and solve my mount issue all together?
Do I need the CRV/Si timing belt mount?
THANKS ERRBODY
dc2_dustin!
Apr 14, 2014 08:46 AM
B20-V-EG6
Oct 14, 2007 09:23 PM
full Circling
Nov 22, 2006 09:30 AM
LegoZ81
Dec 3, 2003 07:43 PM
3rdGteg
Sep 27, 2002 05:56 AM
