C-lo Nitrous H2B 391 HP STOCK BLOCK
Supertech springs and retainers
Skunk2 pro 2 cams
removed butterflys
removed balance shafts
RMF looking headers i got from full throttle
68mm throttlebody
3inch intake pipe with velocity stack
E85 fuel
everything else is still STOCK!!
im using ectune with a demon board
Skunk2 pro 2 cams
removed butterflys
68mm throttlebody
E85 fuel
Re: C-lo Nitrous H2B 391 HP STOCK BLOCK
Good ****!
Always wanted to see what my car could do with a big shot
Good luck at the track, I wanna see what that'll run
Has this engine been taken apart, been honed, had rings done? Just asking as I had ring gaps set to stock on my engine, and the ring overheated and touched, breaking ringlands on #3 with a 100 shot.
Granted mine was an H23 crank and rods with H22A pistons, so higher compression.
i never opened the block. it still has the same headgasket and headbolts from when i bought the motor at jdmenginezone.com
thanks and the best part about that traction bar is that its lower than my headers and oil pan so that always hits before anything lol
BIG BUMMMMMMMMMPPP to you C-LO very NYCE now ur motivating me to do the head n add a shot lol.. what type of Tranny you're using??
G-MO
01-29-2003 05:50 AM
