96 civic sedan swap 94 b18c1
i was wondering what wiring harness, ecu i would need to run since i have a 94 b18c1, the car i have is a 96 civic sedan. help would be appreciated.
Re: 96 civic sedan swap 94 b18c1
Well my 94 b18 uses a obd1 wire harness, the 96 civic uses the obd2 wiring. What i did to put my b18 in my 96 civic i took a 93 civic wiring and replace the 96 obd2 wiring with the 93 obd1 wiring, but you can convert the obd2 wiring to obd1 to hook up to the motor or you can convert the motor to obd2. There is alot of post out there to do it just have to look around.
DJ Nokturnal
11
10-31-2003 02:20 AM
u2civic1
07-19-2003 10:01 AM
