h2b wouldn't go into gear HELP
Ok so here's the deal we bought an h2b del sol and for the first few hours we were driving it shifted fine than it started to not want to shift or go into gear. It has an evolution kit. We switched out the slave cylinder and still wouldn't go into gear. We didn't get a chance to switch out the master because no parts store had it in stock, so now the car is 3hrs from home at a friends house. We are going back this Saturday to hopefully fix it. Oh and when i start it in first gear it jumps while i still have my foot on the clutch pedal. What do you guys think my problem is? I need to prepare ask the things i need before i take the 3hr drive back to get it fixed.
Re: h2b wouldn't go into gear HELP
Ok so here's the deal we bought an h2b del sol and for the first few hours we were driving it shifted fine than it started to not want to shift or go into gear. It has an "evolution kit". We switched out the slave cylinder and still wouldn't go into gear. We didn't get a chance to switch out the master because no parts store had it in stock, so now the car is 3hrs from home at a friends house. We are going back this Saturday to hopefully fix it. Oh and when i start it in first gear it jumps while i still have my foot on the clutch pedal. What do you guys think my problem is? I need to prepare ask the things i need before i take the 3hr drive back to get it fixed.
and make sure that when you push the clutch pedal in the slave is actually working, it should travel 3/4 of an inch if not more then that, check your master cylinder and if all that checks out its the clutch or you bent the evo clutch release fork
i quoted your problem
if it goes in gear while the car is off and doesnt go in while the car is running and your fork moves when you press the pedal, your pressure plate is probably messed up
Ok thanks, ill be switching the clutch out for a new clutch kit them ill see how it goes from there
its not the clutch save your time and money... Learn from my mistakes
read my child read and learn....
https://honda-tech.com/forums/drag-racing-36/h2b-shifting-problems-2387935/
allmotorgsr98
Transmission & Drivetrain
12
06-05-2011 10:25 PM
killahatch
05-19-2009 07:38 PM
jimmyfloyd182
05-07-2007 07:41 PM
