B20ek speedo problems
Old Apr 29, 2012 | 04:26 PM
SOLFOOD94's Avatar
Default B20ek speedo problems
I am trading my del sol for a swapped civic and the speedo works but twiches and jumps around as it accelerates.....
Any info????
Old Apr 29, 2012 | 04:41 PM
JdmCoupe91's Avatar
Default Re: B20ek speedo problems
^Check the speed sensor connection on the trans. Any CEL?
Old Apr 29, 2012 | 04:43 PM
SOLFOOD94's Avatar
No cel showing bulb light upon startup. And speed sensor seems to be undamagedinternally ans externally
Old Apr 29, 2012 | 05:26 PM
InTheZoneAC's Avatar
take off the distributor cap/rotor, the cover underneath the rotor and check the connections to the ignition control module. tug on them and see if they slide easily in place or if they're snug.
It's easier to do this with the distributor off so just mark a line with a marker on the top adjustment where the distributor meets the block before you start taking the distributor off.
you can also take the ignition control module to autozone and they'll test it for you. Their little machine shows all green lights when everything is good, if any red light comes on something is wrong with it.
jayare05
Nov 22, 2013 11:55 PM
pspryu101
27
Dec 12, 2010 11:14 PM
dumbchild
May 5, 2004 06:40 PM
TwoPointZero
Mar 27, 2004 07:23 AM
Brian_92GSR
May 21, 2002 04:46 PM
