b17 swap 2 questions
Alright So i pulled the dseries out and i am putting the b17 in... Only my driver side motor mount mounts up... DOES anyone know how or WHAT i need to order for the rear trans and side trans mounts?? is it just the ones from the 93 integra or whaT?
sorry if this is not in the right sections.
Re: b17 swap 2 questions
b17 shares the same block casting as a b16. b16 block is shorter in hight than a b18/b20. So ANY b-series exhaust mani will fit.
Not a eg...92-95 2-dr ex chassis code is ej1.
Ok man thanks , still looking too see what mounts i need. i know i need is the L bracket. Also i know i need the clutch pedal for the cable
You need 92-95 civic 5spd mounts or integra mounts cause they are the same and the t bracket for an ls or gsr 5spd doesn't matter. Auto mounts wont work if your car was auto. Good luck with it.
The manual mount has different bolt holes on the top. I'll keep looking and thanks the block is just sittin above the bay just waiting to be dropped
