couple questions with my 96 ek with b18c1
hey h-t.
im throwing this code and i am not able to hit vtec and even at times my car goes into limp mode where i cant rev past 3500 or somewhere around there. is there anything i can try to look into which could be the possible fix? car was obd2b and i have a jumper harness for p28 obd1 which is chipped. heard it could be the chip or an even worse thing. so im just stuck on what to do lol hmm think thats bout it.
http://www.youtube.com/watch?v=YmkIS...ature=youtu.be
ohh also when i am going into second gear i have a pretty bad grind, unless i shift extremely slow, i mean slow. when im normally driving it still grinds, havent raced on it yet since i dont want to **** it up even more. someone said it could be a bent shift fork? readjusting my clutch (brand new stage 1 clutch)? or just my second gear?
any help is appreciated. if its in the wrong place, please direct me the right way. thanks in advance!
Re: couple questions with my 96 ek with b18c1
if its only grinding in 2nd it might be the 2nd gear synchro. and it looks like your throwing code 20 to me which is ELD i believe
i was thinking the same bout the tranny just wanted a second on it since people were telling me it might be other **** you know and yea thats what i thought, where could i start with that, could that be a reason of the limp mode?
hope this helps GL
thanks, havent had the time to do this cause ive been so busy. ima try other dudes idea then this hopefully soon.
anyone know why i am not cracking vtec or why sometimes my car would go into limp mode? think if i get this eld **** figured out itll fix that problem or is it a whole different issue
or is it in limp mode all the time your saying? lol thanks homie, i hope ill be able to try that soon. car is starting to get me angry lol
smooz EK
03-02-2006 12:17 PM
