B18B turbo swap and auto to manual conversion
B18B auto to manual conversion
SWAP HELP
My 94 EG auto to manual conversion,
Is was a lot easier then I would think it was.
Last edited by Johncivic3; 07-27-2015 at 03:10 PM. Reason: Needed to add more info
Re: B18B auto to manual conversion
I have a 1994 EG that I finished the auto to manual conversion on, it works great, only down side is I can fill the heat off the exhaust on my shifter.
Any idea the best way to stop the heat transfer?
thanks
thanks
Seagull Management
Re: B18B turbo swap and auto to manual conversion
'94 - '01 Integra or '99 - '00 Si.
'94 - '01 Integra/'99 - '00 Civic Si/'94 - 97 Del Sol VTEC or you can use '90 - '93 Integra axles with the matching intermediate shaft and driver's side axle seal.
If it's a USDM harness you can use it and it will make your life a lot easier. If it's a JDM harness you can't.
Run an OBD1 LS ECU ('92 - '93 PR4, or '94 - '95 P75)
So that said. I read more then one place that the cars body harness WILL work with the LS Eng. harness. IS that right. and if so what do I do with the ECU. the cars body harness is obd1-do I just get a LS ODB1 ECU and not use the ODB2 one. or do I use the OBD2 and get a jumper or something...I just dont want a Check eng light or the ecu to thro a code. that is what the inspection stations in NJ look for.
Thanks. The Motors harness is JDM..The Cars body harness is for a D16A6..
So i should just get the LS ODB1, ECU..Cool.
this wiring thing is a pain,
I still have the D16a6 motor harness, but will it work on the LS
https://www.facebook.com/HondaSwapTech
Lx Civic 99
01-02-2014 05:56 PM
