Intermediate shaft differences?
Old May 10, 2012 | 01:13 PM
98slowvicEX's Avatar
Default Intermediate shaft differences?
I have a 97 gsr swap in a 94 civic hatch. My trans went out so today i picked up a Y21 b16 transmission. Both transmissions are hydraulic. I have it installed, but the intermediate shaft doesn't fit. I have the shaft the whole way into the trans, but the 3 bolt holes don't line up. It seems the shaft is about 3/4 of an inch or so too long. How can this be? I was under the impression that 94-00 B series intermediate shafts were all the same? Any ideas? I need to get this back together to get to work tomorrow. Thanks in advance.
Edit: my intermediate shaft is stamped sr3-jo and is 14 inches long from the end that does into the trans to the edge of the thick mount part.
Old May 10, 2012 | 04:17 PM
Default Re: Intermediate shaft differences?
I looked online and found the OEM honda/acura part numbers. They say 97 gsr's, 97 del sol vtecs, and 99 SI's have the same intermediate shaft?! How can this be? Something is wrong here. I need help ya'll.
Old May 11, 2012 | 09:09 AM
UPDATE:
First off, there is a TON of misinformation on the internet. Both, on this website, and across all the honda/acura forums. All intermediate shafts for 94+ hydraulic B series are NOT the same. I have a 97 gsr swap in a 94 civic hatch. My transmission went out and i replaced it yesterday with a Y21 SI transmission. My intermediate shaft seemed to be about 1/2 an inch too long. After much research here, and other forums almost everyone was saying it should work. Well it doesn't work. I picked up a 99 civic si intermediate shaft and they ARE different lengths. One is about 5/8 of an inch longer. They are also visually different. I would be more then happy to post a picture of them both next to each other if anyone cares.
So for future reference: 94+ gsr integras use one intermediate shaft, while the others use the other choice. There is TWO choices.
Old May 11, 2012 | 10:04 AM
kyden's Avatar
i think there was just something wrong with yours. they are NOT different. perhaps you got one off an automatic?
Old May 11, 2012 | 02:28 PM
There couldn't be anything wrong with the original intermediate shaft, it worked perfect with the gsr transmission. It was a 5 speed, as is the SI transmission so an automatic Int. shaft would of never worked for me in the first place. The only thing i changed was the transmission, from gsr to b16. The intermediate shaft i have worked fine before with my gsr transmission. I have them both sitting here, they are OBVIOUSLY different lengths. Sitting them next to each other with a tape measure says one is 5/8 of an inch longer. The 99 SI intermediate shaft fit right in. The gsr DOES NOT. I tried them both multiple times. It is a fact that i can't get anyone to grasp because of the gross amount of misinformation spread on the forums.
Old May 11, 2012 | 03:14 PM
BryanM.'s Avatar
Resident Gearhead
Yes they are all the same part and all have the same part number, 44500-SR3-J01.
You don't need a different intermediate shaft to us a Y21 on a B18C1 block. Something is wrong on your end.
Everyone on the internet is wrong except you? lol
Old May 11, 2012 | 03:18 PM
BryanM.'s Avatar
Resident Gearhead
Also, I am using a B18 intermediate shaft on my B16 with a Y21.
But, according to you, this isn't possible.
Old May 11, 2012 | 05:46 PM
You can say what you want, but i am the one here with a tape measure. I wil upload a picture of them both, next to each other to show you. I called honda and spoke to someone in the tech department and he confirmed what i said. Me, my mechanic, and my friend who has built countless B series swaps are all wrong? We just can't get it in there right and we all 3 can't use a tape measure or visually tell they are different lengths? Not true. Tell me why i can take this gsr intermediate shaft and try to install it but its too long, then 2 seconds later i can take the SI Int. shaft and install it an it fits perfect? I threw the gsr trans back in just to check it out and it was the same way.
Old May 12, 2012 | 10:02 PM
Lord Helmet's Avatar
up for pics
Hondatherdm
10
May 26, 2010 07:55 PM
jah.tien
Mar 16, 2010 07:35 PM
91(si)hatchey
Aug 16, 2009 06:36 PM
DeDonDeRosa
Dec 14, 2005 08:33 AM
