B18 problems.
Old Apr 30, 2012 | 09:05 PM
Freckles's Avatar
Default B18 problems.
I just finished putting my B18b1 in my EG hatch. The harness came plugged into the motor already so i really didn't have to plug anything in except for the parts where the motor goes to the car.
Problem is, I try to start the car and it turns over, I think I have spark cause Im getting backfire from the headers.. It turns over, and if you pump the gas it'll turn on for a second then just die out. Fuel pump is primering, starter is working fine.
I'm wondering if it's a sensor, or something unplugged that's making it do that? Any help please.
Old Apr 30, 2012 | 09:20 PM
jbpnoman's Avatar
Default Re: B18 problems.
Test your fuel pressure - You should be getting ~40PSI to the top of the filter, according to service manual specs.
Check your spark ("I think" doesn't do much good). It should be white. Also, make sure you have your wires in the right cylinders.
Get a timing light, and check your timing.
Old Apr 30, 2012 | 09:35 PM
Freckles's Avatar
I'll try to check that tomorrow, but could it possibly be the MAP sensor? What are those 3 sensors on the intake manifold. One of em is the MAP sensor, what about the other two
crave13k
Sep 2, 2011 11:33 PM
mooze
10
Nov 28, 2009 03:03 PM
PhanatNy
Jan 31, 2009 12:01 PM
LilRckt
Feb 21, 2004 06:08 PM
bluedelsol
Feb 16, 2003 05:36 PM
