GSR swap no spark, no fuel please help!!!
Recently I did a swap, 2000 GSR engine into a 1996 EK hatch dx. I used a 96-98 ex obd2a Ek harness to the p72 ecu the swap brought. I plugged in a green plug to the car and two plugs in the ecu on blue plug and one small grey plug(one grey plug I could not plug in). I noticed the Dizzy plug from the EX wiring harness was cut off (shame on me for not checking) so I took the plug from the GSR harness and wired it to match the colors; only one blue wire was left.
When I went to turn on the car, it started to crank and at first if just kept cranking no start. Then I noticed that the fuel pump wasn't priming and that I wasn't getting any spark. I did some research and found out that ckf by the crank pulley needed to be rewired and in order for the engine to start; I wired it and still crank no start, no spark, no fuel pump prime(I noticed that my check engine light is not coming on).
I checked all the grounds (transmission housing, thermostat housing, and engine block near the driver side headlight). Check main relay I can hear it click. Then I decided to go get a jumper harness from obd2a to obd1 with p28. I hooked everything up and nothing.
I would greatly appreciated it if I can get some assistance.
Re: GSR swap no spark, no fuel please help!!!
D15 hatch I checked main relay, its clicking. Before the swap everything was working find no issues at all. Which wiring are you talk specifically are you talking about so i can double check.
Junior_rigo
04-23-2015 07:50 AM
fcbdolphinz
09-08-2009 03:54 PM
Jkim81
11
10-25-2008 05:04 PM
