97 sedan b18c typer bulid
Hi people i'm new to the fourm and i need so expert opinions. Im in the process of a major bulid I have 10kfor motor internal and some bolt ons and i want all motor NO FORCED INDUCTION AT ALL!!!!!!!!!!!!! I need suggestion and or changes to the internal aspect. Is mix and macth the best or stay with the same brnd through out the bulid. And by all means if you can save me some money please do so. My goal is 300 whp*
Internal
B18c type r $3599
Bc stroker $1954
Bc spring and retaniners $342
Bc camshaft *$464
Bc cam gears *$180
Bc valves kit *$454
port and polish $300
Bolt ons
Aem fuel reg $126
Skunk 2 fuel rail $210
Victor x $290
Aem hybrid induction intake $221
Edelbrock headers $411
Skunk RR exhaust *$508
Aem fuel filter $110
Msd distributor $558 ??????? Maybe????
Edelbrock fuel injectors $60 each
Hondata s300 $300 used
Skunk 2 alpha throttle bodies 70mm $134
Internal
B18c type r $3599
Bc stroker $1954
Bc camshaft *$464
Bc cam gears *$180
Bc valves kit *$454
Bolt ons
Aem fuel reg $126
Victor x $290
The Grumpiest
Re: 97 sedan b18c typer bulid
Question. Why did you put together a parts list and not know if it was going to get you to your power goal or not?
Did you copy these parts off of a build making similar power?
The Grumpiest
I had some "Honda guy" tell me once that my Ebay headlights were worth $500 because they were rare. Keep listening to the people.
With that budget I think I could build 2 nice turbo cars and have cash left over.
This is the forum you need to be posting in and searching through.
So that means you don't know for a concrete fact. No I don't have suggestions since this isn't really the proper forum. And I shouldn't have to give you any if you did some hardcore research. Talking to a wannabee Honda guy isn't research.
EK9
Well you should have your idea now between all of your threads getting the same responses. Your not going to get anywhere near 300whp, especially with the parts listed youd be lucky to make 240whp. Just cuz 4piston did 270 with stock stroke doesnt mean you can come close to that
The Grumpiest
Start making use of this link before you start posting and spamming the forum with the same question thinking you're the first one trying to make 300hp N/N on a B-series.
https://honda-tech.com/search.php
I'm not talking "ish".
Have you tryed it
The Grumpiest
See u r getting the worng idea so i will dead you right now ( no ideas or suggestion no need for you to post reply) and im not stupid think no one has thought of it or tried just have not hear or seen any fails or success and if it was a fail what was the out come of it
Have you tryed it
Have you tryed it
BTW you posted in a public forum I can post anywhere i choose to.
I predict you will NEVER complete, or even start, this build.
Tried what? Researching? Actually putting a build together without asking anyone on this forum A SINGLE QUESTION? Actually putting together a parts list that I knew would make the power I wanted? Not spending a mint to try and go fast because I thought that N/A was more reliable?
The Grumpiest
Tell You what then. Write a check for $10k and tell the shop to get 300hp out of it. Also tell them to try to save a buck or two while you're at it. Done.
The Grumpiest
Thanks! I will.
Oh! Here's the Google search results that would have told you what you're planning is near impossible. https://www.google.com/search?q=300+...ient=firefox-a
so you are gonna go with 3 differnt companies for an Intake manifold and fuel supply/fuel rail? I dont think the Aem fuel regulator will work with the skunk2 fuel rail and i dont think the Skunk2 fuel rail will work with a Edelbrock intake manifold. i tried putting on my friends skunk2 fuel rail with my edelbrock intake manifold and the injectors seem like they were slightly gaped differently.
