b18c1 civic.......suspension questions
Re: b18c1 civic.......suspension questions (vw-honda-hatches)
the shocks i want to get (kyb agx) have the same part number for 92-95 civic and 92-95 integra......
Ususally the struts are the same since the Civic and Integra are similar. The springs though, they usually have a stiffer spring rate for the Integra. I would go with Integra rate springs if possible.
ok
H&R race springs for my 95 civic cx drops the vehicle.....
2.5-front
2.0-rear
While the race springs for a 95 integra drop it
2.0-front
1.75 back
My car is a 4x4er and I am positive I want to do the civic height, but can i change or get my own spring rates? Does any body know the rates for h&r race for 95 integra and civic?
2.5-front
2.0-rear
2.0-front
1.75 back
from what i know and been told the springs rates are the same with civic and integs...its the struts that are diffrent...just upgrade your front shocks to integ spec and you should be good.
Re: b18c1 civic.......suspension questions (eg6si)
If I use the Tein Flex w/ EDFC will it work for semi-track, and daily driving for my hatch?? I was also going to use the JIC setup but Im not sure
integra front struts are different? they have the same part numbers for kyb and tokico.
h and r race spring part numbers......
95 civic - 50145-88
95 integra - 51863-88
maybe i should just call h and r
95 civic - 50145-88
