is anyone running the jim fab rear and two front lower motor mounts?
I did not read this the first time but it says civic rear.
can I still run this on my integra?
also here are the front lower
I am thinking about running all three (if it works) instead of buying eurothane inserts.
mike
[Modified by infamousLSVTEC, 10:54 AM 2/7/2003]
mike
Re: is anyone running the jim fab rear and two front lower motor mounts? (infamousLSVTEC)
Yes. I e-mailed him about it. He said that he forgot to put "Integra" on the site when he made it, and hasn't had the time update it.
Re: is anyone running the jim fab rear and two front lower motor mounts? (InfamousRS)
I am running the TQ. mounts. If you don't like the car to vibrate DO NOT get these. They bring out every little sound.
I love mine
I love mine
Re: is anyone running the jim fab rear and two front lower motor mounts? (rolow)
i dont care about the sound I just want no engine movement...
I also would like to get his traction bars
Re: is anyone running the jim fab rear and two front lower motor mounts? (infamousCRVTEC)
what will happen if i get the jimfab motor mounts with extra stiff bushing?
will there just be more vibration in the interior?
or should just stick to the regular jimfab mounts?
Re: is anyone running the jim fab rear and two front lower motor mounts? (TEAM JSJ)
unless you spray anti-vibration goop on the firewall your going to have many problems... my lsvtec almost fell apart because of the mounts, I lost thirteen bolts in my oil pan with jim fab mounts. I would recommend using lock tite on vital bolts.
mike
mike
