what is needed?
you'll need a mount kit, a shiftlinkage that is made to fit (i believe several places make them), a PR3 or PWO ECU, axels, and i would also suggest replacing the water pump, timing belt, along with the plugs and thermostat. Oh also a teg throttle cable and clutch cable. not sure if you need the clutch cable but i just went ahead and replaced mine. also don't forget new fluids, and don't forget a hasport wiring conversion harness if it's a dx
[Modified by EVOCELICA, 7:28 PM 2/18/2003]
