Wiring up the motor b16a fisrt gen to 98 civic ex
The motor is in the car a b16A frist gen into 98 civic, with the 99-00 civic SI ecu two of the clips plug in with one remaining does anyone know how to wire this up
or the wire digram to these.
Thank you for your help
Re: Wiring up the motor b16a fisrt gen to 98 civic ex (ITR632)
What?? You can't use a 99-00 P2T in a 96-98 unless you do some MAJOR wiring modifications. Find yourself a 96-97 Del Sol VTEC ecu or convert to obd1 and run an obd1 P30 or a chipped p28. You'll save yourself a lot of pain doing it this way.
best bet is to get a pr3 or pwo ecu... i dont know if anyone makes an obd II to obd0 conversion ecu harness... just be thankful that you are not in cali... good luck
Re: Wiring up the motor b16a fisrt gen to 98 civic ex (madtownhonda)
Your not going to want to run an obd0 ecu in a 98 civic EX. Trust me on this, an obd2 P30 (Del Sol VTEC) will plug in to the EX harness and will work 100%. You can also use a 96-98 -> OBD1 conversion harness and run an obd1 P30 which are easier to find than the DS VTEC ecu.
Re: Wiring up the motor b16a fisrt gen to 98 civic ex (VTECVillain)
Does anyone have a P30 or del sol vtec which are hard to find. Thanks for your help guys
Zulu451
Engine Management and Tuning
13
02-24-2021 08:48 PM
T3KNiQe
06-10-2009 02:16 PM
who00knows
08-09-2002 10:48 AM
