ls/vtec???????
Old Feb 14, 2003 | 03:04 AM
nsxblueteg's Avatar
Default ls/vtec???????
hey guys I'm thinking about starting an ls/tec and was wondering on my 93 teg do I have to find an obd1 head or will a nonobd head work also and I would just have to use my distributor? Any info would be great thanks guys.
Old Feb 14, 2003 | 03:32 AM
civichopeful's Avatar
Default Re: ls/vtec??????? (nsxblueteg)
A non-obd head will work just fine. Use your obd1 distributor like you mentioned and yuou should be fine.
Old Feb 14, 2003 | 09:33 AM
Jeff C's Avatar
If your dist if from an ls, you will need to cut one of the mounting legs off the dist in order for it to fit on the vtec head.
Old Feb 14, 2003 | 12:56 PM
khcivic's Avatar
Default Re: ls/vtec??????? (Jeff C)
jeff is right i ran and ls distributor in my b16a for almost a year then the coil started going bad and finally got a b16 distribtor.
Old Feb 16, 2003 | 08:41 AM
nsxblueteg's Avatar
Default Re: ls/vtec??????? (khcivic)
thanks guys now I just need to find a head
Big_S
Sep 7, 2004 08:17 PM
Dennis93ac
Oct 30, 2003 03:51 AM
I 8 1 U 8 1 2
Sep 17, 2003 01:08 PM
delux247
Apr 4, 2003 05:57 PM
