Wire IDs for secondary O2 EK sensor used as Primary O2 sensor
Folks,
Due to horrendous 'budget' overruns with my LS/VTec with OBDI wiring conversion in my EF I'm going to try to use a secondary O2 sensor I got out of a salvage yard as my O2 sensor. It's from an EK Civic. The EK secondary O2 sensor has 4 wires, 2 black, green, and white one. (I'm running an OBDI GSR ECU).
I need to know which wire is 12V switched, which is the 12V O2 heater, which is the O2 sensor signal, and which is the O2 sensor ground?
Thanks much, Dave K.
dkasakitis
02-14-2003 08:04 AM
