PR3 ECU problem
Old Feb 10, 2003 | 07:02 AM
sleeper4dr's Avatar
Default PR3 ECU problem
i've had my PR3 chipped for years now with a mugen chip and just recently i've decided to switch back to a stock program to see if it might cure my part-throttle knock.
i've now tried my stock ECU chip AND a stock programmed chip (because i have a socket) and both of them give me a code for an ECU problem (solid non-blinking LED).
any ideas or suggestions? could my ECU be bad? just bad chips?
thanks
Old Feb 10, 2003 | 11:25 AM
eg6ajk's Avatar
Default Re: PR3 ECU problem (sleeper4dr)
its possible that static has damaged the chips or you inserted tehm wrong way
another problem could be that when installing the chip you push on the board damaging something in the process
Old Feb 10, 2003 | 03:27 PM
sleeper4dr's Avatar
Default Re: PR3 ECU problem (eg6ajk)
i made sure i was installing the chips the correct way.
and the thing is that i can ALWAYS drop my mugen chip back in and the ECU always works. but if i try the chip with the stock PR3 program, i get the solid LED.
today i even went over the solder points for my socket and it resulted in no change. PR3 stock does not work. MUGEN does.
Old Feb 10, 2003 | 05:43 PM
Jaker's Avatar
Only possibility is bad chips. If it was something else, the Mugen chip would not work.
panchlow
May 18, 2011 07:34 PM
Exempt
Engine Management and Tuning
10
Oct 3, 2008 11:11 AM
ILS_Thatstight
Sep 22, 2006 12:37 PM
Sp33dStarVirus
May 30, 2003 08:58 PM
tinkerbell
Dec 16, 2002 02:12 AM
