gsr crank in an ls block?
ok if i put a gsr crank in an ls block would that increase hp and torque alot and would i need to use the girdle and would this affect cr and is it a good idea thx
Re: gsr crank in an ls block? (black-hatch)
why would you do that, the ls crank is used for ls/vtec b/c it increases displacement, you will decrease the displacement by putting a gsr crank in a ls motor
i asked the same thing a few months ago. There is no reason to do it. Use the GSR crank in the GSR block.
03EM2guy
19
03-28-2011 06:00 AM
