B series into 92 hatch question??
I have a 90 JDM B16A that i am trying to put into my hatch. I need to know what motor mounts i need to make this work. Are the stock mounts from a 94-95 Integra or do I have to buy the Hasport or HCP mounts? I have searched with no real answer on this subject so I thought i would post here.
Matt
Mraudio13@aol.com
Matt
Mraudio13@aol.com
Re: B series into 92 hatch question?? (mraudio13)
You can use the integ's upper driver's side mount and make sure you have the bracket that bolts up to the block for that mount to work. You'll also need the rear mount bracket off of a 94 up integ. Finally, you'll need the a/c bracket and mount off of the same 94 up integ. What tranny are you going to use??
Re: B series into 92 hatch question?? (1bad-eg)
i have a cable tranny right now, i am looking into a hydro. still don't know yet, i am just trying to figure out the rear and driverside mount.
what I was trying to say was that you'll need to change the bracket that the driver's mount bolts up to from the b16a to the newer 94 up integ. So you'll be replacing the mount and the bracket. For the rear you're going to replace the civic's with the the integ's ( 94 up of course). If you need more info, im and leave you number. It's alot easier to explain on the phone.
wm5holla
07-24-2003 01:12 PM
