B-series Mounts in a 98 ek coupe????
I was wondering about which mounts i need in a 98 civic. It was automatic which makes matching up mounts for a b-series even harder. Can anybody help me on this. Which ones should i get and out of what year or should i buy a hasport mount kit. Thanks for your help.
If anybody has any of the mounts i need hit me back at lowcivex@yahoo.com
Re: B-series Mounts in a 98 ek coupe???? (lowcivex)
anything about the automatic tranny mounts. Will a 5 speed b series mounts bolt in if not what kind of modification is required
thanks that site really helped.
The part number for the rear tranny bracket is: 56027-S04-N10
It says "rear tranny mount" ... but you need the bracket, not the mount. Just trying to help you out, because I was using that page when I did my swap.
I wish they'd change that..
Re: B-series Mounts in a 98 ek coupe???? (stroker)
The lower mounts are gong to give you a little problem. There is a metal tab on both sides that will have to be removed, before you can install the mounts from a 99 and up Si.
As you can see.....they are the almost exactly the same. You need to use the one on the right, which is the stock one. This applies only to the Front trans mount and A/C mount.
Re: B-series Mounts in a 98 ek coupe???? (Nameless)
Well...I suppose if you want to do it the hard way then you can whip out the grinder and go to town. I would prefer just to do the easier thing.
Re: B-series Mounts in a 98 ek coupe???? (madtownhonda)
That's the rear tranny bracket I used and it was fine. Wonder if Honda changed their numbers???
Re: B-series Mounts in a 98 ek coupe???? (Trey)
Hey Trey, I just recieved my 2 mounts for my swap (rear tranny bracket and driver's side mount) As far as the driver's side mount, it doesn't look the same as in the pic you show on your site. This is a rough drawing of the side view of the mount I got. It has the same part number as you listed. If you ask me, it looks like it has an extra hole at the very bottom
Let me know what you think
Re: B-series Mounts in a 98 ek coupe???? (zgrieger)
You have to remove the timing belt cover to install it. You'll see that there is another bolt underneath the timing belt cover.
jestin91
12-19-2012 08:29 AM
