Yes or no on this setup please give detailed answers
Is this a good setup b16 head with a b20 block
-b16 tranny
-type r valvetrain and cams
-ctr pistons with eagle rods
-frankenstein ecu redlining at 10000
- type r intake manifold
- fuel reg with type r injectors
could i get better cams making power at like 9000+ with a good valvetrain with the ctr pistons and eagle rods but with a stock block and type r injectors
-b16 tranny
Re: Yes or no on this setup please give detailed answers (97hb)
Stock b20 sleeves will not handle a rev of 10,000Rpm if i am correct... CTR pistons will not fit in a B20 block....
To rev to 10k safe you'd better make that block bullet proof.. That means getting Golden Eagle sleeves or a Dart Block and doing all ARP bolts and a Z10 block girdle and a valvetrain that will support that also...
Before you go and attempt something like this you best get as much research and facts cause attempting to rev a motor at 10k might only last one time and at that 10k you'll hear a loud bang or something of the sort....
But anyways enjoy yourself and have a great day
Re: Yes or no on this setup please give detailed answers (Outkast)
b20=alot of research and then more research and thenNO OE PARTS ls vtec are great ls rods itr pistons and ur done! with etc vtec parts
