New Project: 2.2L B-series motor
The top pict is crappy pict but it's a pict of my old B20 motor (right side, stock 84mm) and my new B18B block, sleeved by Golden Eagle, at 87mm. Actually, when using a GSR crank & rods for this setup, it'll yield approximately 2.14L but still the same bore size as a stock H22 block. You can somewhat see that the spacing between each cylinder is a lot less now. Also, going into that block will be some stock Prelude SH pistons, calculated to be in the high 10's for compression. Haven't decided on what head to use.... might just use a P&P LS head to keep the motor a sleeper for now. Should be a pretty good comparason compared to my old H22 EG hatchback, and to our shop's H22 EK hatchback, so I'll let you all know how this feels (torque wise) compared to a H22 motor. I'll have more/better picts later..... some picts with a 81mm and 84mm piston inside of the bore so you can see how much bigger it is.
Re: New Project: 2.2L B-series motor (Newman)
Wow, now that is going to be a sleeper motor. A 2.2l with a 1.8 stamp...sweet.
EDIT: BTW, those walls are thin. You sure they will hold up?
[Modified by Jeff C, 3:56 PM 2/13/2003]
Re: New Project: 2.2L B-series motor (Jeff C)
i cant wait to hear what this engine is capable of though!
Re: New Project: 2.2L B-series motor (sleeper4dr)
thats what i want to know. it seems to me that the general concensus on the 'safe limit' for cylinder sleeves is 85-85.5mm. how long do you expect this setup to last and does the sleeve thickness have anything to do with why you've chosen a 10:1 CR?
MEAT PATTY
Re: New Project: 2.2L B-series motor (illdezignzls)
I have seen thinner cylinder walls then that. SportscarCompact when they had that right up on Loofsey car and Bisi car well it was about their motors they were running. Their cylinder walls were about half the size of that, crazy ****. Survival of the fittest headgasket.
holy crap. Newman, you are nuts. here's for you though, I gotta say I am interested in how this turns out.
Are there any issues with H pistons on B rods?
Re: New Project: 2.2L B-series motor (owen_the_soyboy)
FYI: all the Prelude SH is is a stock H22A4 with a special tranny (the sistem is called ATTS). someone correct me if I'm wrong but all USDM H22A1-4 are 10:1 compretion, H22A JDM compretion is 10.6:1, and the JDM H22A Prelude type-s compretion is 111:1. hope that helps. just ask around in the Prelude forum. BTW, that is going to be an awsome engine. keep us posted.
Interested finding on the prelude pistons with the 87mm bore. I went with a 86mm bore on my GE sleeved gsr block with 12.5:1 comp. I wanted to go pretty extreme, but not 87mm extreme. I am waiting on the block to return from GE assembled, should be a pretty interesting set-up. 2.1L b-series with 12.5:1 compression should be pretty nasty. Good luck with your project!
Re: New Project: 2.2L B-series motor (boosted hybrid)
I have faith this will work because I had a 86mm from golden eagle but you will have trouble sealing with 87mm, there has been a lot of discussions on here on the headgasket failing on 85mm and larger. I would use lots of copper spray and block sealent and hope for the best... good luck
Re: New Project: 2.2L B-series motor (There is no sp00n!)
Rods are GSR.... just about everything is still stock Honda parts (no aftermarket forged pieces like rods or pistons). Some machine work to make the Prelude pistons fit onto the GSR rods but otherwise it works. I'll take picts of the assembly later.... been busy lately with containers coming in from Japan
Wow, going with stock internals too! Seriously this is a very interesting project. I never would have imagine using prelude pistons in a b-series engine a few years ago. Gluck!
https://honda-tech.com/zerothread?id=415580
nice setup man..there is another thread similar to this one and there is a lot of good info there to about a 2.2l gsr also, i just really want to know how reliable this steup is.!??!?
[Modified by i want a civic, 12:33 PM 2/16/2003]
Re: New Project: 2.2L B-series motor (Jason kiDD)
I would think a 2.4ltr h22 would have been more of a project to take on. But good luck..
On my next EG, I'll do something H22 again with a lil twist
How about 2.2l with only a 84.5mm bore. Yes b-series. Done it before with aftermarket cranks. You are going to have problems with headgasketat 87mm. Is this a street car or race?
Re: New Project: 2.2L B-series motor (1FSTCAR)
The r/s ratio is going to be total **** on the engine. 87mm is extreme on the bore, which is why i played it safe with the 86mm bore. I'd rather keep the stock gsr r/s ratio of 1.59:1 and a 2.1L displacement, then get a 2.2L displacement with 1.4:1 r/s ratio with the 95mm cranks. For a daily driver, the stock crank, 86mm bore, 2.1L combo is the best you can get without deckplates or aftermarket blocks. The gasket seals well at 86mm with copper spray.
