is it that easy for this swap???(b16/91 HF)
Okay i just got done reading the info on the website listed on my sig. and besides the rewelding of the passenger side motor mount, which for my father should be no prob.(i don't weld!) and the four wires, is really simple.
i did my own ZC swap so i know what to expect and maybe that's why i'm so relieve about the swap.
is there anything else i should worry about?
the guy talks about using the 86-89 teg axles(fine there) and relocating the 'back" tranny mount to the right(ok with that also) and do the wires...
that's pretty much it.
i'm swaping a b16 off a delsol, anything else to worry about?
thankx for the time
thankx for the time
Re: is it that easy for this swap???(b16/91 HF) (joey1320)
Why don't you by the mount kit...if you're getting a b16 off a del sol i'm sure its a b16a2(hydralic style transmission). On a 91 crx you're using a cable style transmission. Go to hasports(www.hasport.com) to for the mounts from cable to hydralic.
On a side note...eric's page(the link you posted) he's using a b16a1(first generation) and I think at the of his swap mounts weren't available.
[Modified by tazmoe, 4:30 AM 2/16/2003]
Or you could use a B series cable tranny and the OBD0 parts from a JDM first gen B16 to make life much easier.
EF8IGHT
17
12-03-2005 12:03 PM
freeeked
08-24-2003 10:41 PM
Rob!
17
01-03-2002 04:05 PM
