Tranny leak problem
Old Feb 12, 2003 | 09:53 PM
MHill's Avatar
Default Tranny leak problem
I swapped a B16 into my 5th gen hatch and seem to be having a problem with the tranny leaking fluid where the passanger side half shaft meets with the diff......
It is a decent leak, leaves a spot if parked in one place ver night.
The seals seem ok but how small of a tear will affect the leak?
Does anyone else have this problem, or possible a remedy?
Old Feb 12, 2003 | 11:40 PM
jdmWONG's Avatar
Default Re: Tranny leak problem (H2FOV)
it sounds like its a bad oil seal.i put a tranny on my car and the same thing happend, i bought new seals, put them in hasnt leaked a drop since. there only like 10-20 bux just try that, im willing to bet its your problem.
Old Feb 13, 2003 | 05:12 AM
1bad-eg's Avatar
Just make sure that when you're putting the axles back in, that you don't tear the new seals. Just take your time and you'll be all right.
Old Feb 27, 2003 | 03:21 PM
CHRIS 1.8's Avatar
Default Re: Tranny leak problem (Blow'N'CRX)
Is the oil seal the axle seal? A black round seal right?
Old Mar 1, 2003 | 05:00 PM
smokey2.0's Avatar
Default Re: Tranny leak problem (CHRIS 1.8)
http://www.hondaautomotiveparts.com/...ISSION+HOUSING
item 18, that's what you have to replace!
Inextricabledrvr
Nov 26, 2009 11:03 AM
C32B2
Aug 9, 2005 04:03 PM
ITSTOCK
Aug 10, 2004 10:04 AM
raene
Jun 18, 2002 09:06 AM
