tranny question. need help
Old Feb 11, 2003 | 09:22 PM
black92si's Avatar
Default tranny question. need help
ok guys, need some help here. i have an s1 tranny in my 92 si. for those of you who may ask, i am using the hasport cable to hydraulic conversion on a 1st gen b16a. anyway, my tranny has developed the common third gear grind. it's getting pretty bad and i want to repair it. the question is, where can i get replacement parts for this trans? i can't find anything at the honda parts dept. is there a USDM part # for the syncros that i can use? any help would be great, TIA!
Old Feb 11, 2003 | 11:36 PM
Kamin's Avatar
Default Re: tranny question. need help (black92si)
i think you have to have JDM ones shipped in.
Old Feb 12, 2003 | 04:30 AM
KENLUDE97's Avatar
Default Re: tranny question. need help (Kamin)
Yea i had a 5th gear grind in my Prelude. The syncros. And i changed out the Tranny oil for GM Syncromesh brand oil. I no longer have the grind and i can NOT make it grind!! Give it a shot it is worth the $20 and it sure is alot easer then rebuilding the tranny.
Old Feb 12, 2003 | 09:49 AM
black92si's Avatar
Default Re: tranny question. need help (KENLUDE97)
i think you have to have the JDM ones shipped in.
dammit.
i tried replacing the fluid, no dice.
Old Feb 12, 2003 | 10:12 AM
KENLUDE97's Avatar
What kind of fluid did you use? I tried the Honda MTF first and that did not work then i went the GM Syncromesh...
Old Feb 12, 2003 | 03:03 PM
V3locity's Avatar
yea, dammit it is. I'm pretty sure you have to get jdm synchros shipped over unfortunately.
Someone please tell me if i am wrong.
Old Feb 12, 2003 | 05:51 PM
VTECVillain's Avatar
Default Re: tranny question. need help (illdezignzls)
There are no US replacement synchros to my knowledge. If you had a 92-93 GSR YS1 cable tranny then the B Series hydro synchos would work.
Old Feb 12, 2003 | 05:52 PM
black92si's Avatar
honda MTF, GM syncromesh and castrol GTX. haven't tried sythetic yet, but i think it's a mechanical failure. i have a kaaz LSD so i wanna repair it. don't think getting another tranny will really help since it's bound to have the same problems...
Old Feb 12, 2003 | 05:54 PM
Well maybe not another S1 but a newer GSR, Si or ITR hydro tranny would be a better upgrade IMO. Then you wouldn't have to worry about tracking down small parts like that.
Old Feb 12, 2003 | 06:13 PM
black92si's Avatar
i'm not sure the kaaz will fit in any of the hydro trannies
natedizzle
May 9, 2010 12:14 PM
delsol revolution
May 2, 2007 08:08 PM
HmgLauj69
Dec 31, 2004 05:19 PM
Turbo_Man
Jan 15, 2003 05:02 PM
