OBD1 distributor....differences (LS only)
Old Feb 10, 2003 | 11:13 AM
Doodoo's Avatar
Default OBD1 distributor....differences (LS only)
Just a FYI....
I have been trying to convert my Si over to OBD1 for abnout 3 weeks now. I have been held up mainly by which distributor to buy that bolts up.
My motor is a 1995 LS, the head was cast in 94.
I have been using a 90-91 distributor for OBD0 just fine. All 3 bolts line up.
I took a OBD1 distributor off of a 92-93 LS when I first did my swap so I had this laying around. When I went to install this distributor only ONE bolt would line up with the head.
This week end I went to find the correct distributor. I found a 96 LS dist. This one does not have the correct foot-print either. It looked similar to the 92-93. Also, all the wires are in one common plug instead of two.
I finally found a 94-95 dist. The foot print matched the 90-91. Weird. I installed it and all 3 bolts matched up.
So it seems that the 92-93 LS were bastard OBD1 cars. My quest to have all 3 bolts in my dist. worked out.
I have pics if anyone wants to see them. Send me an Email and I will send them.
HTH
Old Feb 10, 2003 | 06:08 PM
infamousALLMTR's Avatar
Default Re: OBD1 distributor....differences (Doodoo)
3 weeks....
ouch, you should of just rewired it to a obd-1 dis. wire clips then it would of worked perfect... just a FYI
sittin on GOLD
Jan 27, 2009 03:06 PM
AMLS4dr200whp
Jun 1, 2007 06:24 PM
Ak_ef9
Nov 2, 2006 11:26 PM
6doorsentra
May 30, 2006 07:12 PM
