almost done with swap into 88 crx and question about front mount
i m post it again and asking about the mount.. i just brought the mount kits for integra engine and it s work great but they only send the three engine mounts.. but what about the front mount???? i did install the b18a motor into the crx and put the crossmember annd it s doesnt fit so i hammer it and it s fit...i dont know if i suppose to put the front mount??
Re: almost done with swap into 88 crx and question about front mount (dutchman5)
you cannot use the front mount you need to shave it down or just cut it off don't worry about you need it
you cannot use the stock front mount, the bracket on the crossmemeber does not line up. If you want one and what to run a large header you can get the place racing crossmemeber for around $250 which comes with the front mount. We are using one in a b20 vtec turbo set up and works very well
Peace
Peace
B16Civic93
04-16-2007 12:16 PM
90redintegra
12-08-2006 06:17 AM
