Help plz Vtec doesnt work
Old Feb 10, 2003 | 06:00 AM
The Real Funk's Avatar
Default Help plz Vtec doesnt work
Its a 1st gen b16 in a 90 crx hf. I have no codes but vtec wont work. The temp guage doesnt work right either. It will get warm then drop back down to below the C and raise back up all while driving. Should i replace the thermostat? Also should i try replacing the vtec solenoid? Sorry this is my first swap (me and a friend did it) and we are really not sure whats wrong.
[Modified by The Real Funk, 10:04 AM 2/10/2003]
Old Feb 11, 2003 | 09:57 AM
nsxmatt's Avatar
Default Re: Help plz Vtec doesnt work (The Real Funk)
Try pulling a sensor like the map and see if it throws a code. Make sure it's not your light. Also if your temp doesn't go up then VTEC will no engage. Engine has to be warm to work. Change your thermostat and see what happens.
Old Feb 11, 2003 | 11:28 AM
irev210's Avatar
are u sure u hooked everything up properly, it seems like you have a poor temp connection.
Old Feb 11, 2003 | 12:05 PM
xsolidcellx's Avatar
Default Re: Help plz Vtec doesnt work (irev210)
either that or crossed wires, also check oil pressure...low pressure no vtec
Old Feb 12, 2003 | 07:18 PM
Default Re: Help plz Vtec doesnt work (xsolidcellx)
Ok thanks alot guys. My friend works at honda and he just got me a new thermostat. We are going to put that in on friday and see what happens. Ill keep you updated.
TristanW10
Mar 15, 2010 03:33 PM
99jdm_itr
Nov 1, 2009 12:01 PM
MyIntegra
Jun 12, 2009 10:54 AM
tallguy
15
Mar 29, 2005 10:36 PM
b16aeg
Aug 2, 2002 04:41 AM
