EK with R swap. which a/c bracket?
Old Feb 9, 2003 | 12:18 PM
B_CRUZ!'s Avatar
Default EK with R swap. which a/c bracket?
which a/c bracket would I use if I wanted to retain the a/c?
Old Feb 9, 2003 | 02:18 PM
SC61HB's Avatar
Default Re: EK with R swap. which a/c bracket? (B_Cruz)
I'll be getting my R for my EK in April (on backorder from Password JDM). Anyways, you need to get a Del Sol A/C bracket to retain your A/C.
Old Feb 9, 2003 | 02:39 PM
Anthonyl469's Avatar
Default Re: EK with R swap. which a/c bracket? (zgrieger)
I used me stock 99-00 si bracket.....
Old Feb 9, 2003 | 02:53 PM
B_CRUZ!'s Avatar
Default Re: EK with R swap. which a/c bracket? (Anthonyl469)
cool just double checking thanks.... weird **** though is I read this months HCI mag or something like that and it said you cannot retain the that ac pump for a b series. you would need to use the a/c pump for a Si with the bracket.
Old Feb 10, 2003 | 07:50 AM
integra6650's Avatar
o just ditch it who cares about your comfort when your car is 50 lbs lighter
Old Feb 10, 2003 | 07:59 AM
B_CRUZ!'s Avatar
Default Re: EK with R swap. which a/c bracket? (integra6650)
no my car is pretty light stock. I have no a/c. just asking for a friend.
Old Feb 10, 2003 | 09:20 AM
Trey's Avatar
25 Year Member
P54 bracket will work.
Check out http://www.jspectuning.com/6gen
Old Feb 10, 2003 | 09:31 AM
B_CRUZ!'s Avatar
Default Re: EK with R swap. which a/c bracket? (Trey)
thanks trey I found that link to be very helpful. you must have modded your sig lately because I swear you had a 6th gen swap link on there.
Old Feb 10, 2003 | 10:32 AM
Trey's Avatar
25 Year Member
I did because my ISP is being a biotch. That link above is a lil older and is missing the IAVC info. YOu don't need it if you have the EX though.
Good Luck!
geebs
Sep 24, 2008 05:46 PM
95_cxhatch
Apr 9, 2008 04:26 PM
stehigs321
Jul 10, 2003 01:24 PM
ef ect
Jan 22, 2003 07:09 PM
