how to remove pins?
Old Feb 11, 2003 | 11:45 AM
black-hatch's Avatar
Default how to remove pins?
can someone plz post some pics of how to remove ecu pins and explain it cause i dont know how to do it
Old Feb 11, 2003 | 06:58 PM
tommyboy's Avatar
Default Re: how to remove pins? (black-hatch)
Don't have pics to show, but all you have to do is use an eye glass repiar kit screwdriver and pull back the little tab thats connected to the pin, pull the wire at the same time and the thing will come right out.
Old Feb 11, 2003 | 08:14 PM
VTECVillain's Avatar
Default Re: how to remove pins? (tommyboy)
Everyone has their own methods and tools of the trade. I use a sturdy sewingmachine needle and sometimes a flathead precision screwdriver. I don't see how it's possible to make a how to with detailed pics.
Old Feb 12, 2003 | 11:39 AM
tnbigdawg's Avatar
Default Re: how to remove pins? (VTECVillain)
i use paperclips.
Old Feb 12, 2003 | 08:39 PM
Bs's Avatar
Bs
Default Re: how to remove pins? (tnbigdawg)
https://honda-tech.com/zerothread?id=377845
Some connectors have a flap like the one pictured above, and other cars (pre obd) have what looks like a small white comb once you either lift the flap or pull out the "comb" all you have to do is pull the wire on the backside of the connector.
[Modified by B_s, 5:41 AM 2/13/2003]
SCMFOX
Dec 21, 2017 09:16 PM
AH419
Engine Management and Tuning
Aug 10, 2012 03:27 AM
eclypzex
Welding / Fabrication
Apr 12, 2008 07:35 AM
ekdriven
Mar 8, 2005 08:00 AM
FourthGenHatch
21
Apr 17, 2003 04:35 PM
