?'s should i get a helms manuel for my swap?
i will be attempting to swap a dohc zc in my 91 civic hatch si during the summer. so i am now doing my research. i have never done a swap before, so i was wondering if the helms manuel will guide me step by step thru the swap? all i have ever done to cars are rotate tires, oil change, radiator flush, install intake, install headers, change battery, fuse, spark plug and that is about all i know how to do. how hard would you think this swap is for someone like me to do. will the helms manual help me at all?
Re: ?'s should i get a helms manuel for my swap? (91_hatch_si)
Bump I'm interested as well.
*edit* I'm a newbie when it comes to cars.
[Modified by lazy bum shaughn, 11:50 AM 2/8/2003]
I don't think a Helms manual would be necessary for that swap in your car. Since you have an Si, the wiring is almost exact to the ZC with only a few changes that need to be made and it's a direct bolt-in. The info you need, you could easily get from the internet and besides they don't make a Helms for the ZC since it was a Japan only motor. Here's some links:
http://hybrid2.honda-perf.org/tech/zcinfo.html
http://hometown.aol.com/nosajuf/nosajuf.htm
http://www.hasport.com/Tech/Wring/88...20to%20B16.PDF
taeim
12-27-2007 10:54 PM
C_R_X_V_T_E_C
12-23-2006 07:20 AM
stevocivic
Honda Civic (2001 - 2005)
05-31-2006 10:25 PM
