b16 swap question's crx to od1
i bought the obd1-obd0 distributor harness and the obd0-obd1 ecu harness. my car is a crx hf and i also have the hasport wiring conversion to a b16. do i wire the hasport wiring to the obd1 pins that conect to the ecu or the pins that conect to the obd0-obd1 conversion harness? where do i wire up the obd1 o2 sensor at and what do i do with the original hf o2 sensor wire? can anyone walk me through this?
Re: b16 swap question's crx to od1 (crx1856)
i don't know the answer to your questions, but i bet hasport does. call them up, they'll more than likely walk you through everything.
PhatwhipsJDMkits
10
11-11-2004 06:38 AM
