obd2a->obd2b jumper
Old May 20, 2003 | 09:05 AM
pdiggitydogg's Avatar
Default obd2a->obd2b jumper
alright, is there anything else i need to do for an obd2b ecu to work on an obd2a harness? Just throw the jumper harness on and im set right?
(searched)
edit**yeah i know i need to wire up knock sensor
Old May 20, 2003 | 06:01 PM
Default Re: obd2a->obd2b jumper (pdiggitydogg)
bump
Old May 20, 2003 | 06:17 PM
SilverEk3dr's Avatar
Well.....I did this myself (99 civic, running of a 96 prelude ecu) All you need to do is buy the extra plug that you dont have. If your car is 96-98 OBD2A you have the "D" plug(smallest one), but you need the B plug (second plug) And if your car is 99-2000 obd2B (or 2001 for a prelude/integra) then you need the D plug and not the B plug
Then you need to buy a shop manual, and go to town on the re-wire (its not hard just time consuming)
I looked but I cant seem to find pics of the ecu plugs...but you get the idea.
How about a little info on the swap? etc...
Mark
Old May 21, 2003 | 07:02 AM
Default Re: obd2a->obd2b jumper (SlvrEj6Dx)
oh yeah i know about all the ecu plugs and even have it memorized on what they look like.
I was just looking for confirmation that I just need to run an adaptor harness or re-pin my obd2a wiring harness for an obd2b ecu, for everything to work...Im having a bit of paranoia right now about it...lack of confidence in what I think is right
edit**whoops...99 b18c into 97 civic ex
nicko360
Mar 28, 2007 03:59 PM
white_panther
Oct 7, 2005 06:24 AM
JDM CTR EK
Mar 24, 2005 03:54 AM
busmcrs
Jan 9, 2003 09:49 PM
