Explain this Dyno
Old May 20, 2003 | 08:23 AM
BuCU's Avatar
Default Explain this Dyno
Why is there a huge dip there besides it being the vtec cross over. This is a GSR motor bored out to 84mm....
Old May 20, 2003 | 11:57 AM
Timmay's Avatar
Default Re: Explain this Dyno (TeamElusive)
maybe lower your vtec x-over a bit?
good numbers though
Old May 20, 2003 | 01:18 PM
Mentat Ghola's Avatar
Default Re: Explain this Dyno (1slow4door)
DAHM!!! thats with stock compression? whats the displacement of a 84 mm GSR block? is 84 mm like 30' over?
Old May 20, 2003 | 01:24 PM
W.O.T.'s Avatar
Default Re: Explain this Dyno (The B Man)
The scale is not based at "0" and so the graph looks worse than it really is...
Old May 20, 2003 | 04:55 PM
NXLude's Avatar
THats a pretty normal dip for vtec....without an AF reading its impossible to accurately help you
Old May 20, 2003 | 04:58 PM
Kamin's Avatar
Default Re: Explain this Dyno (W.O.T.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W.O.T. &raquo;</TD></TR><TR><TD CLASS="quote">The scale is not based at "0" and so the graph looks worse than it really is...</TD></TR></TABLE>
still drops 20hp.
i would like to see what the AF numbers look like
you should try lowering the vtec xover to 53-5400ish
what ECU you running?
Old May 20, 2003 | 05:01 PM
NXLude's Avatar
Default Re: Explain this Dyno (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
still drops 20hp.
what ECU you running?</TD></TR></TABLE>
If you look the drop is less than 10 hp....not a big deal....
Old May 20, 2003 | 05:02 PM
Kamin's Avatar
Default Re: Explain this Dyno (NXLude)
excuse me
20TQ not hp.
dohcgarage@714
Honda S2000
26
Nov 8, 2007 11:29 AM
DARKTEG_
Aug 31, 2006 01:02 PM
cvp467
22
Jul 5, 2006 06:04 AM
hondahans
23
Apr 12, 2004 01:01 AM
