h22a help please!!!
Old May 29, 2003 | 07:04 PM
jinxster's Avatar
Default h22a help please!!!
i have just install my h22a in my 94 accord ex. some of the engine wiring harness do not match up to the car's harness....what do i do?
Old May 29, 2003 | 07:16 PM
VTEC-DA's Avatar
Default Re: h22a help please!!! (jinxster)
What year is the motor and what wiring harness are you using?
Old May 29, 2003 | 07:27 PM
poison's Avatar
All sensors should match up and be in the same place.
If you have a JDM H22A swap, then you will need to use the Accord EX factory engine harness.
As for everything going on, everything should go right onto it and match up. What particular sensors are you missing on?
The ONLY other thing that would come into play, is if you have an OBD2 H22A. Then you have yourself some more things you need to do.
Old May 29, 2003 | 08:36 PM
Newman's Avatar
New User
Default Re: h22a help please!!! (poison)
Also the wiring is going to be different on the harness with the external coil setup, and if you have a JDM OBD-1 H22, then it'll be using an internal coil and the wiring will need to be modified on the harness. Otherwise, for the most part 98% of the plugs will be the same.
Old May 29, 2003 | 11:28 PM
aeolus's Avatar
Default Re: h22a help please!!! (Newman)
http://www.h22a.org/5gswap.htm
Old May 30, 2003 | 10:56 AM
jinxster's Avatar
Default Re: h22a help please!!! (VTEC-DA)
i have a obd1 jdm h22a
Old May 30, 2003 | 10:57 AM
jinxster's Avatar
you are saying to cut the main wire harnes and use my accords in place of it?
Old May 30, 2003 | 11:46 AM
preluder's Avatar
i dont think you need to do that cause im using my original harness from my 92 so? comon guys lets help this guy out?
johnsoj0266
Mar 31, 2013 04:04 PM
230 cougar
Jul 27, 2009 10:55 PM
aznevanchoi
Mar 1, 2007 08:00 AM
