usdm gsr swap question into my 91 dx hatch
I was wondering if i would be able to replace my whole wiring harness seing as how it comes with the ecu and full harness. Is this doable? If so it would make my life easy.
Re: usdm gsr swap question into my 91 dx hatch (sprayed91hatch)
id rater just swap out the harness just like the motor and the ecu so i dont need to wire up for mpfi,vtec and all the other sencers, and lets not get into the obd0 to obd1 switch. Just thinking the harness swap would be the **** (if there is such a thing) let me know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sprayed91hatch »</TD></TR><TR><TD CLASS="quote">I was wondering if i would be able to replace my whole wiring harness seing as how it comes with the ecu and full harness. Is this doable? If so it would make my life easy.</TD></TR></TABLE>
Trust me when I say that trying to use the entire GSR harness is not going to make your life easy, in fact it will make the swap 100 X's more difficult. If harness swapping were that easy then you wouldn't find a lot of info on wiring up MPFI, VTEC, etc. You will need to transfer your DPFI harness onto the GSR motor and rewire to MPFI and add the necessary extra wires.
Re: usdm gsr swap question into my 91 dx hatch (VTECVillain)
Are you talking about doing the whole car harness? Every wire switched with the GSR? Its possible. YOud need a GSR car wiring harness and gauge cluster, and a VSS isntead of the speedo cable. dahm that would take some labor though.
Ryrie1995
05-21-2016 06:52 AM
91H4hatch
09-01-2006 12:24 PM
Beau Gotti
02-12-2006 02:11 PM
OutLuDeD
08-16-2003 06:30 AM
