90-93 ls swap into 89 civic?
is this do able? if so what is needed? i thought the civic has a cable tranny now does the ls have a hydro or cable tranny. also this is for a buddy of mine and i also searched
thanks
luis
thanks
luis
Re: 90-93 ls swap into 89 civic? (95gsr)
Yes it's do able. You will need an aftermarket mount kit like HASport and such. And the LS has a cable clutch tranny.
If your car is a DX or STD model, then you will also need to convert to multipoint.
HTH.
HTH.
depends on what you replace seal etc after buying the motor. long block w/tranny,mounts,braket for a.c. (i live in az),shift linkage,pr4 ecu,axels,new water pump etc since you're using a b series instead of the stock d series.
if you have any questions feel free to im me sometime. i'm in the process of doing this swap myself.
ProjectJDMIntegra
10
01-20-2006 05:42 AM
BuBBa y0!
12-16-2003 07:13 PM
