Guys, will this work?
Old May 26, 2003 | 05:47 AM
CRneXt's Avatar
Default Guys, will this work?
I am doing a swap for the THIRD time, but I never ased this question before... WILL IT WORK? If not tell me why please.
I am swapping a B18A1 into a 1990 Civic SI. I am using the stock Si wiring harness on the B18, and putting that into a integ ECU.
I don't have an integ ECU. Can I use the Civic/CRX Si ecu??
thanks for your logical, and explained answers.
Scott AKA CRneXt
Old May 26, 2003 | 06:51 AM
CRneXt's Avatar
Default Re: Guys, will this work? (CRneXt)
come ON!!!!! no one will relpy to this??? Not even a half answer?
Dudes is everyone outside for memorial day?
Old May 26, 2003 | 08:52 AM
raene's Avatar
If the B18 has all the same sensors that the CRX has, then there's really no reason it won't work. I highly doubt it'll be an optimal solution - a 1.8L is going to require different fueling curves than a 1.6L - but it should get you where you're going until you set something better up.
Old May 26, 2003 | 09:03 AM
aLLjDMRalf's Avatar
no it wont work, ur gunna need the obd0 ecu u out of a 90-91 ls or rs, but the harness should work fine, and the ecu should plug in
Old May 26, 2003 | 09:53 AM
raene's Avatar
Default Re: Guys, will this work? (SlOwCrXbUtUbNbEaT)
Why won't it work?
Old May 26, 2003 | 10:26 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Guys, will this work? (raene)
Your going to run lean.... I would crank up the Fuel pressure till you get the right ECU. And yes a 90-91 LS RS ECU WILL work. Have fun!
Blaze
Old May 26, 2003 | 04:33 PM
Newman's Avatar
New User
Ok, since there's a lot of mixed info here, I'll try to make this simple.....
If your "B18A1" swap is from a 90-91 Integra, then yes it'll all plug right into the CRX harness and no wiring will need to be done. If your B18A1 is from a 92-93, then it's an OBD-1 motor and the wiring and some electronics will be different so you'll need to either change or swap out the sensors/parts accordingly to run OBD-0.
Yes, your CRX ECU will work and you won't have any ECU codes, but it won't be making the B18A LS motor run at full potential. Get yourself a 90-91 Integra 5-spd ECU.
Old May 27, 2003 | 04:22 AM
CRneXt's Avatar
Default Re: Guys, will this work? (Newman)
Newman,
Yes, this was the answer that I needed. I guess that I should have asked a little differently. I knew that I am going to have to swap some sensors. to fit the new harness. I knew that the ECU would plug in I just didn't know whether it would run the engine or not, although logic told me it *would*. This makes #3 for me. I just never had to use an SI ECU. Is it going to run like hell? Erradic idle and stuff like that?
I was concerned about the fuel curves, etc... being wrong.
Anyway, thanks all for the answer... keep up the discussion.
Scott
Modified by CRneXt at 7:34 AM 5/27/2003
Old May 27, 2003 | 02:04 PM
bigblockEG's Avatar
I think it will run...think you are going to want to run an LS ECu though... For safety
drumri0t
Jan 25, 2016 06:19 AM
patdow1
Apr 21, 2009 04:35 AM
PACT man
Oct 21, 2006 08:49 PM
vyxx-ct
Honda Civic (2001 - 2005)
Aug 3, 2006 07:05 PM
